Moi3D & Free Ai without any MCP !
 1-2  3-22  23-42  43-50
12142.43 In reply to 12142.39
@Rich
> No offense to anyone intended but I'm quite sick of the (years and years now) of
> spam posting and my guess is others are also - is there a way to block certain
> posters Michael?
Yes, in the lower right corner of a forum message there is a link labeled "More".
Click that to open the "Post Options" menu and on that menu choose "Relationships".
That will take you to the "User Relationship" setting for that user and you can set the option for "Ignore" and then push "Save" at the bottom.
You can also get there by going to Options (on top bar) > Relationships (on left bar).
12142.44 In reply to 12142.41
> I think the parts of the car are these slices of varying widths, from front to back!
That's unfortunate because it generally isn't feasible to construct a complex shape with a lot of localized detail like a car body just with one single surface lofting through cross sections.
With complex forms like a vehicle body it needs to be made up of multiple NURBS surfaces, not just one single surface and many of the surfaces should be larger extended shapes that are trimmed.
If you want to produce a model using data that is basically the same as a 3D scanner point cloud then generating a sub-d polygon mesh model is a better approach.
> The goal was to see whether it was possible to obtain surfaces—or, better yet, volumes inside
> Moi3D—generated by the machine based on a sketch!
The answer looks like "No" since I haven't seen anything but very poor quality surfaces posted so far.
12142.45 In reply to 12142.42
> Yes, you can request any type of segmentation—for example, every 30 cm—or
> divide the whole or specific parts into any number of sections you’d like!
In general with NURBS modeling it usually does not help to increase the density of cross sections.
Most often the result of that is that undulations get compressed and become more visually prominent.
The kind of segmentation that you would want is one that follows shaping features instead of only being sampled in world axis directional slices.
Shaping features are something like this - areas of the model that have a distinctly lower radius of curvature within a localized region are where you want a fillet or blend transition between 2 separate patches:
You can then get a good idea of the patch boundaries. But not all of the boundaries are necessarily going to be a "natural edge" of the underlying surface, some will be formed by making extended areas that are then trimmed.
This is a quite advanced and difficult type of NURBS modeling to do, it's a lot easier to do it with subd surfaces where there is no extension or trimming you just need to manage a lot of small elements instead but locally smooth blending is also automatic with subd.
The area where NURBS modeling is strongest is when much of the model is accurately described by 2D drawings like with mechanical parts.
EDITED: 26 Nov by MICHAEL GIBSON
12142.46 In reply to 12142.44
@ Michael
I suppose the slice parts are for communicate more easily with the user...
Ai Front view proposal (whitout sketch so pure Ai imagination justified )
I have given it the 3/4 bottom sketch, its first blue print and the realist view generated)
Fichier 3dm when new curious problem of importation will be resolved!
EDITED: 27 Nov 6:40 by PILOU
12142.47 In reply to 12142.46
Frenchy you can clearly see that the left front of the result sketch is total rubbish. You can’t get sensefrom nonsense.
12142.48 In reply to 12142.47
@Bin
I am not yet qualified for see if it's pure rubbish or not when i read that...
Aesthetic approach and surface continuity
Fenders and front wheel arches: a pronounced, taut curvature that extends the dynamic flow of the profile, complementing the wheel arches already established in the wireframe base.
Hood and low-slung nose: a gentle downward slope toward the front, featuring a subtle central bulge and fluid edges that capture the momentum of the original sketch.
Lighting signature and air intakes: slim, integrated headlights that follow the tension lines, paired with sculpted lower air intakes to provide visual balance with the rear diffuser.
NURBS surfaces (sculpted hood with integrated front fender curvature + lower splitter) and guide curves (leading edge of the nose, central spine, and left/right front wheel arch arcs).
NURBS surfaces (Entity 128): sculpted hood with integrated front fender curvature and lower splitter.
Closed trimming curves (Entity 126):
Front headlights (left and right): profiled closed loops projected flush against the fender curvature, ready for "Trim" or "Project" operations.
Side air intakes (left and right) and central intake: closed contours prepared for cutting or extrusion between the nose and the splitter.
Hood air extractors (left and right): longitudinal loops aligned with the channels on the hood.
Structural guide curves (Entity 126): leading edge of the nose, central spine, and front wheel arch arcs.
Sculpted front hood with integrated fender curvature + lower aerodynamic splitter.
Leading edge of the nose, central spine, left/right front wheel arches, closed contours for the front headlights, side/central air intakes, and hood extractors.
Curious some days Gemini seems have different teams!!!
A day no problem for make something another day ask to do exactely the same thing is impossible!
I ask to it...different teams ?
<< Yet I swear that’s not true! :)
<< There hasn’t been a change in the team—I am an AI system, and this behavior is simply a result of how the tools and output formats are made available within this session.
For user result is same than different teams! :)
EDITED: 27 Nov 10:49 by PILOU
12142.50 In reply to 12142.48
Well yes, and this is the root of the problem.
You are quick to post any results you generate using AI, and you seem to assign value based on it having required little effort.
When I ask what does that have to do with MOI you post obviously garbage models like this:
You post about how wonderful the guide steps are even for novice users and fail to post any result in MOI from actually trying to use them.
In short, you post big piles of automatically generated junk, declaring that it's all great.
It is not hard for me to understand that users who are operating as skilled craftsmen find this to be both annoying and ever more straying into being actually offensive to their own values.
So please Pilou, stop posting AI related content on this forum.
Previously I was going to make a separate section for you to post AI slop in but I'm thinking now that is not the best because other topics using AI as a productivity enhancer to help with real work are not causing any problem here.
It's just you posting AI slop that is the problem.
So stop doing it please.
Thanks, - Michael
Show messages:  1-2  3-22  23-42  43-50
