Moi3D & Free Ai without any MCP !
 1-2  3-22  23-32
12142.23 In reply to 12142.22
> No the blue realist car above was from this ... no wast time all take 20
> seconds ... input Sketch ... BluePrint ... Render
Yeah the AI does that part well.
But what does that have to do with MOI?
This is the MOI forum, not the AI discussion forum.
12142.24 In reply to 12142.23
About points of Polylines you was right i don't move a point...
So use another strategy normally that is true curves no hidden Polylines
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/general_line2s.3dm
next time it will be accrording the first sketch, can't test now overpass my quota
My Moi French Site
12142.25 In reply to 12142.24
What is the point of using the AI generated curves at all? They do not capture hardly any of the defining characteristics of the sketch.
So far everything you have shown going into MOI has just been useless junk. That part is what is a waste of time.
12142.26 In reply to 12142.25
<< What is the point of using the AI generated curves at all?
It just for try to avoid the first step to tranform a Sketch in curves named automatically!
I believe i have found a workaround! Sorry named Objects and Styles are in French!
Curves here must be not Polylines!
All time elapsed from send Sketch .. blue Print Result ...a control render (head thread) ... generating files... to results curves inside Moi is less a minute!
Here i have enter any name, it's only Ai name! But seems well adapted! :)
https://moiscript.com/uploads/3/9/3/8/3938813/process_from_sketch.3dm
Loft etc ... can be done normally... in Moi3D...
EDITED: 24 Nov by PILOU
12142.27 In reply to 12142.26
No Pilou, it doesn't look like the sketch.
It's missing most of the shaping from the sketch brush strokes.
What's the point of using a sketch if the result doesn't look at all like it?
12142.28 In reply to 12142.27
It seems I simply hadn't asked for enough curves!
And that, to avoid polylines, all I had to do was ask for smooth NURBS!
There is no name here but no problem to add them after because
The 56 curves were generated in a specific order, grouped by color and geometric function (axes, fenders/flanks, roof/glazing/rear oval, wheel arches, cross-sections, and finally the tail/diffuser/fins), which makes it very easy to assign them clear and consistent names, should you wish to do so later.
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/56_courbes.3dm
And no problem to change any form!
(for example: a more elongated or more compact oval, a more triangular/tapered shape, a more steeply raked rear window, or a hood/glazing arrangement that conforms more closely to the rear deck and trailing edge). The relevant curves (and/or the entire wireframe) can then be regenerated while maintaining continuous NURBS curves defined by control points.
12142.29
Under ‘User options’, I’ll choose ‘Ignore’
- Zooen
12142.30 In reply to 12142.28
Pilou, it's just the same problem again.
You keep on posting a screenshot of a bunch of curves loaded into MOI. What do you think that accomplishes?
You seem to think that surfaces in MOI are just going to magically appear from these curves.
For example this indentation area in the blue wire:
Is represented by this one single vague curve in your 56 curves file:
How do you expect to make that indented structure with that 1 curve?
Wheel wells are missing about 1/3 of their height in 56 curves:
Should look like this:
Back corners in 56 curves are sharp:
Should be back corners smooth:
I still don't see what these things are supposed to map to:
12142.31 In reply to 12142.30
<< About Wheels: perspective problem absolute Z temporary resolved by a proposition.
But we can ask to put any new measures
<< Regarding the open curve on the lower part of the door
This is part of the recess shown in the sketch who must asked to modify! :)
<<About the pinky diffusers forms
What are diffusers used for?
The primary role of a rear diffuser is to manage airflow beneath the car, generating aerodynamic downforce while limiting drag (resistance to forward motion):
Accelerating air under the floor: beneath a car, air becomes compressed and slowed down between the chassis and the ground. A flat underbody and well-contoured tunnels promote faster, more consistent airflow, creating a low-pressure zone (ground effect) that presses the car against the tarmac.
Slowing and smoothing the airflow at the exit: at the rear, upward-sloping ramps and tunnels—in this case, three at the tail—allow the high-speed air from beneath the car to rise gradually and expand, avoiding abrupt separation or the formation of large, suction-inducing vortices behind the vehicle.
Channeling and guiding the flow: longitudinal fins (or "strakes") prevent air from higher-pressure areas on the sides from spilling into the low-pressure zones within the tunnels, thereby stabilizing downforce during cornering and at high speeds.
In this concept model, the three tunnels—two on the sides, housing the exhaust outlets, and one central tunnel beneath the license plate—provide both a highly distinctive visual signature and a coherent architecture for underbody airflow extraction.
About the process
you can ask any schemas
and Question / Answer about the drawing curves... part by part or not...
Along with the latest batch of curves, we’re essentially receiving a tutorial on which Moi3D functions to use!
As it's only curves ... if surfaces asked it's like thinly sliced ​​ham (chiffonade) :)
So not very practical, to say the least!
We’ll likely have to wait two or three years for this process to improve—to the point where 3D nurbs volumes can be designed directly!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/concept_aero_arche_haute_raccord_moi3d.zip
EDITED: 25 Nov 7:37 by PILOU
12142.32 In reply to 12142.31
Pilou, so what do you think you have accomplished by opening those curves in MOI?
Show messages:  1-2  3-22  23-32
