Moi3D & Free Ai without any MCP !
 1-19  20-32
12142.20 In reply to 12142.18
A few newly learned details!
<< Automatically creating 3D volumes on behalf of the user
That’s what I had assumed, but it’s actually not possible, as AI cannot utilize functions like "Loft," "Blend," etc.—furthermore, DXF and IGES formats struggle significantly with handling 3D volumes and data exchange!
<< Communicating with a human system or a robot
Yes, you are communicating with a robot!
Available 24/7 to discuss any topic!
It can certainly act as a tutor—for instance, helping me understand specific parts of a car—but for now, it cannot perform the actual modeling work for me!
(not access to my interface)
It is up to the user to specify which part they wish to study!
For example, the user must perform a "Loft" operation, guided by the robot’s advice!
In practical terms, for the time being, only the general outlines are generated automatically based on a sketch!
For instance, if the user requests a design for the rear section—and specifies "aerodynamics" in the prompt—the AI ​​can provide reference lines for airflow patterns!
<< All polylines
Sorry, I only have curves?
All can be lofted without any facets.
It produces a sort of "blueprint" that is quite convincing and can be used to create images!
"I cannot generate or provide a .zip file containing the 22 parts of the car because I do not have the complete model broken down into 22 distinct geometric components;
I only have the wireframe view and work focused specifically on the lower rear section."
What you can do instead:
Cut and organize your own parts directly within MoI3D: using your reference wireframe (scaled in meters, where 1 unit = 1 m), you can isolate each area in MoI3D, assign it a distinct Style or name, and save everything into your master .3dm file (or export separate files and bundle them into a .zip archive on your computer).
Automate organization or selection using a .js script for MoI3D: if you create multiple sub-parts or styles in MoI3D, I can write a small .js script for you to help organize or rename them, or to synchronize styles with names/groups.
These same limitations also apply in Rhino!
EDITED: 23 Nov by PILOU
12142.21 In reply to 12142.20
Pilou, you've got to be kidding me.
They are all polylines in the file "general_lines.3dm".
They have a lot of points in them so that they appear to be curved at a glance but if you examine more closely you can see they are just dense polylines.
You can verify by selecting any curve, use Edit > Show pts and move a point:
You can observe this result showing that it's all line segments:
Also you can select them all and look at the "Details..." object properties dialog:
Nope. You will get long strips that are faceted in one direction. You can see the strips in your own image:
hide edges and curves and you'll see the faceting.
"quite convincing" .... Seriously Pilou?
Are you looking at the same thing as me?
How is this piece of junk:
A convincing representation of this? :
What a waste of time.
No the blue realist car above was from this ... no wast time all take 20 seconds ... input Sketch ... BluePrint ... Render
12142.23 In reply to 12142.22
Yeah the AI does that part well.
But what does that have to do with MOI?
This is the MOI forum, not the AI discussion forum.
12142.24 In reply to 12142.23
About points of Polylines you was right i don't move a point...
So use another strategy normally that is true curves no hidden Polylines
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/general_line2s.3dm
next time it will be accrording the first sketch, can't test now overpass my quota
My Moi French Site
12142.25 In reply to 12142.24
What is the point of using the AI generated curves at all? They do not capture hardly any of the defining characteristics of the sketch.
So far everything you have shown going into MOI has just been useless junk. That part is what is a waste of time.
12142.26 In reply to 12142.25
<< What is the point of using the AI generated curves at all?
It just for try to avoid the first step to tranform a Sketch in curves named automatically!
I believe i have found a workaround! Sorry named Objects and Styles are in French!
Curves here must be not Polylines!
All time elapsed from send Sketch .. blue Print Result ...a control render (head thread) ... generating files... to results curves inside Moi is less a minute!
Here i have enter any name, it's only Ai name! But seems well adapted! :)
https://moiscript.com/uploads/3/9/3/8/3938813/process_from_sketch.3dm
Loft etc ... can be done normally... in Moi3D...
EDITED: 24 Nov by PILOU
12142.27 In reply to 12142.26
No Pilou, it doesn't look like the sketch.
It's missing most of the shaping from the sketch brush strokes.
What's the point of using a sketch if the result doesn't look at all like it?
12142.28 In reply to 12142.27
It seems I simply hadn't asked for enough curves!
And that, to avoid polylines, all I had to do was ask for smooth NURBS!
There is no name here but no problem to add them after because
The 56 curves were generated in a specific order, grouped by color and geometric function (axes, fenders/flanks, roof/glazing/rear oval, wheel arches, cross-sections, and finally the tail/diffuser/fins), which makes it very easy to assign them clear and consistent names, should you wish to do so later.
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/56_courbes.3dm
And no problem to change any form!
(for example: a more elongated or more compact oval, a more triangular/tapered shape, a more steeply raked rear window, or a hood/glazing arrangement that conforms more closely to the rear deck and trailing edge). The relevant curves (and/or the entire wireframe) can then be regenerated while maintaining continuous NURBS curves defined by control points.
12142.29
Under ‘User options’, I’ll choose ‘Ignore’
- Zooen
12142.30 In reply to 12142.28
Pilou, it's just the same problem again.
You keep on posting a screenshot of a bunch of curves loaded into MOI. What do you think that accomplishes?
You seem to think that surfaces in MOI are just going to magically appear from these curves.
For example this indentation area in the blue wire:
Is represented by this one single vague curve in your 56 curves file:
How do you expect to make that indented structure with that 1 curve?
Wheel wells are missing about 1/3 of their height in 56 curves:
Should look like this:
Back corners in 56 curves are sharp:
Should be back corners smooth:
I still don't see what these things are supposed to map to:
12142.31 In reply to 12142.30
<< About Wheels: perspective problem absolute Z temporary resolved by a proposition.
But we can ask to put any new measures
<< Regarding the open curve on the lower part of the door
This is part of the recess shown in the sketch who must asked to modify! :)
<<About the pinky diffusers forms
What are diffusers used for?
The primary role of a rear diffuser is to manage airflow beneath the car, generating aerodynamic downforce while limiting drag (resistance to forward motion):
Accelerating air under the floor: beneath a car, air becomes compressed and slowed down between the chassis and the ground. A flat underbody and well-contoured tunnels promote faster, more consistent airflow, creating a low-pressure zone (ground effect) that presses the car against the tarmac.
Slowing and smoothing the airflow at the exit: at the rear, upward-sloping ramps and tunnels—in this case, three at the tail—allow the high-speed air from beneath the car to rise gradually and expand, avoiding abrupt separation or the formation of large, suction-inducing vortices behind the vehicle.
Channeling and guiding the flow: longitudinal fins (or "strakes") prevent air from higher-pressure areas on the sides from spilling into the low-pressure zones within the tunnels, thereby stabilizing downforce during cornering and at high speeds.
In this concept model, the three tunnels—two on the sides, housing the exhaust outlets, and one central tunnel beneath the license plate—provide both a highly distinctive visual signature and a coherent architecture for underbody airflow extraction.
About the process
you can ask any schemas
and Question / Answer about the drawing curves... part by part or not...
Along with the latest batch of curves, we’re essentially receiving a tutorial on which Moi3D functions to use!
As it's only curves ... if surfaces asked it's like thinly sliced ​​ham (chiffonade) :)
So not very practical, to say the least!
We’ll likely have to wait two or three years for this process to improve—to the point where 3D nurbs volumes can be designed directly!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/concept_aero_arche_haute_raccord_moi3d.zip
EDITED: 25 Nov 7:37 by PILOU
12142.32 In reply to 12142.31
Pilou, so what do you think you have accomplished by opening those curves in MOI?
Show messages:  1-19  20-32
