Moi3D & Free Ai without any MCP !
All  1-13  14-18
12142.14 In reply to 12142.13
Hi Pilou, why does it look different than your screenshot?
Here for example in general_lines.3dm these are sharp cornered:
There does not appear to be any hidden curves in the file.
The curves seem to be of very poor quality with some pinched areas and it appears that they are all polylines, not actually any smooth curves in the entire file at all!
What do you think you are going to do with these polylines in MOI?
It is certainly not going to easily convert into a model that looks anything remotely close to the rendering.
Is it that there are more parts meant to be in other files?
The part that is in partie_arrière_basse.3dm looks like it belongs to some other car, the one in the original sketch does not have a rear spoiler.
12142.15 In reply to 12142.11
As for the wheels, one originates from a drawing, while the other comes from generic curves.
Inspect by Style or Name: check the scene browser to see whether these curves share the same Style or if they belong to two different categories (Wheel Arch, Thickness/Skin, Guides).
These are "design intent" curves.
My Moi French Site
As I understand it, the user needs to go through each section one by one and decide whether or not to accept the proposed surfacing!
It remains to be seen whether this actually speeds things up...
General section-by-section workflow:
Isolate and clean up the area—hide the rest of the geometry in MoI3D, check for duplicate curves or stray gaps, and properly group/name the area in the Scene Browser.
Validate guide curves—identify cross-sections, longitudinal rails, and transition edges (such as "U" profiles or wheel arch contours), ensuring they are continuous and correctly positioned.
Propose and test the surfacing—I will suggest the cleanest strategy within MoI3D (using tools like Loft, Sweep, Network, Extrude, or Join to create a solid); you test it on the area, and we make adjustments if the curvature or transition isn't quite right.
Validate and move on to the next section—once the surface or solid is approved, it is organized under its designated Style/name, and we proceed to the next area.
My Moi French Site
12142.17 In reply to 12142.15
They look like garbage, poor quality, all polylines, not useful for much of anything, design intent seems to be attempting to block out the entire car body by cross section as if it can be built in one single surface.
Show me even one useful thing that you can do with them.
12142.18 In reply to 12142.16
WTF I thought the whole point was that the AI was going to do all this work for you automatically?
It is not possible to even begin the first steps of that workflow as the curves are all made up of line segments and none are actually smooth!
In your communications with the AI do they acknowledge that you're actually communicating with a real person in this case and not an automation?
Because it's an area that is not well covered by consumable training data.
Show messages: All  1-13  14-18
