Moi3D & Free Ai without any MCP !
All  1-9  10-18
12142.10 In reply to 12142.6
What is the purpose of these "U" curves?
In the context of NURBS-based aerodynamic surfacing for the lower rear section of a vehicle, this type of regular, repeating pattern is typically used to:
Define the tunnels or channels of a rear diffuser (or air vents/extractors located beneath the rear bumper): each "U" represents the rounded cross-section or profile of a channel designed to accelerate airflow beneath the vehicle.
Serve as section curves or construction rails (for Loft, Sweep, or Network operations) to create smooth surfaces between the flat underbody/ramp and the lower edge, rather than leaving a straight or angular boundary.
Establish spacing and symmetry along the transverse (Y) axis: their consistent, regular arrangement allows for the precise positioning of the partitions or vanes before the surfaces are generated.
How can you verify or utilize these curves in MoI3D?
Isolate or sort by Style/Name: select one of these curves and check its Style in the Scene Browser (or run your synchronization scripts, if they were imported) to see if they have already been assigned to a specific category (e.g., Diffuser, Curves, etc.).
Test a surface connection: select two adjacent profiles or a longitudinal rail and try using Construct → Loft or Sweep to see whether they were intended to form channels or rounded transitions.
Because i have asked "an aerodynamic car"
Other Things
Each part can be described / Groups, Colors etc..
EDITED: 22 Nov 20:02 by PILOU
12142.11 In reply to 12142.9
Pilou, the 3d curves are totally different than the 2D ones.
Look here for example, do these look the same ? :
The 3D curves are an attempt to create the entire car from cross sections as a single surface, it is a very very long way from an actual car model.
What do you think would be accomplished using those curves in MOI?
12142.12 In reply to 12142.10
Maybe you should post the model file with your curves if you were only showing a few of them in your screenshot.
12142.13 In reply to 12142.12
Of course yes general curves are available! lines + names parts
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/general_lines.3dm
And after each parts can be asked one by one like in the post above (maybe 22)
Here only one from the post above! there is of course a little thing to do as it's only DXF and Iges before have the 3dm! :)
Because Colors , names, groups... are not direct from these formats!
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/partie_arri%C3%A8re_basse.3dm
It's like a Puzzle!
EDITED: 22 Nov 19:41 by PILOU
12142.14 In reply to 12142.13
Hi Pilou, why does it look different than your screenshot?
Here for example in general_lines.3dm these are sharp cornered:
There does not appear to be any hidden curves in the file.
The curves seem to be of very poor quality with some pinched areas and it appears that they are all polylines, not actually any smooth curves in the entire file at all!
What do you think you are going to do with these polylines in MOI?
It is certainly not going to easily convert into a model that looks anything remotely close to the rendering.
Is it that there are more parts meant to be in other files?
The part that is in partie_arrière_basse.3dm looks like it belongs to some other car, the one in the original sketch does not have a rear spoiler.
12142.15 In reply to 12142.11
As for the wheels, one originates from a drawing, while the other comes from generic curves.
Inspect by Style or Name: check the scene browser to see whether these curves share the same Style or if they belong to two different categories (Wheel Arch, Thickness/Skin, Guides).
These are "design intent" curves.
My Moi French Site
As I understand it, the user needs to go through each section one by one and decide whether or not to accept the proposed surfacing!
It remains to be seen whether this actually speeds things up...
General section-by-section workflow:
Isolate and clean up the area—hide the rest of the geometry in MoI3D, check for duplicate curves or stray gaps, and properly group/name the area in the Scene Browser.
Validate guide curves—identify cross-sections, longitudinal rails, and transition edges (such as "U" profiles or wheel arch contours), ensuring they are continuous and correctly positioned.
Propose and test the surfacing—I will suggest the cleanest strategy within MoI3D (using tools like Loft, Sweep, Network, Extrude, or Join to create a solid); you test it on the area, and we make adjustments if the curvature or transition isn't quite right.
Validate and move on to the next section—once the surface or solid is approved, it is organized under its designated Style/name, and we proceed to the next area.
My Moi French Site
12142.17 In reply to 12142.15
They look like garbage, poor quality, all polylines, not useful for much of anything, design intent seems to be attempting to block out the entire car body by cross section as if it can be built in one single surface.
Show me even one useful thing that you can do with them.
12142.18 In reply to 12142.16
WTF I thought the whole point was that the AI was going to do all this work for you automatically?
It is not possible to even begin the first steps of that workflow as the curves are all made up of line segments and none are actually smooth!
In your communications with the AI do they acknowledge that you're actually communicating with a real person in this case and not an automation?
Because it's an area that is not well covered by consumable training data.
Show messages: All  1-9  10-18
