Hi Zooen,
After running several tests, I’ve settled on using the OBJ format with N-gons enabled and the angle set to 3. While the file size is larger, it yields better results. MoI3D’s mesh generator creates a very clean topology and precisely preserves vertex normals; as a result, when the model is imported into Blender, curved "hard-surface" areas appear with smooth shading right away, requiring no additional cleanup.
Best regards!
