Scripts installation
All  1-5  6-18
12126.6
You mean the scripts should be placed there: Win-key + R:
%AppData%\Moi\commands
When I do that this path is opened on my Win11:
C:\Users\info\AppData\Roaming\Moi\commands
Something is wrong. No MoI folder in AppData.
In the folder "Roaming" - there is a MoI folder. Idea why?
Mala
Size: 26.8 KB, Downloaded: 3 times, Dimensions: 681x284px
12126.7 In reply to 12126.5
Hi Mala, Burr's archive is listed on the resources page: https://moi3d.com/resources
The link is named "Burr's script archive - collection of scripts posted on the forum".
EDITED: 10 Oct 6:11 by MICHAEL GIBSON
12126.8 In reply to 12126.6
Hi Mala,
Yes, as described in the FAQ question #1
quote:
On Windows you can find the Moi appdata folder by typing Win+R to bring up the Windows "Run" dialog and then type in:
Yes, that's where you need to put them.
Nothing is wrong, it is normal that the MoI folder is located under C:\Users\info\AppData\Roaming\ and not C:\Users\info\AppData\ .
The reason why is that there are 3 different ways in Windows to store user profile data. Just C:\Users\info\AppData\ is not intended by Windows to have data stored in an immediate sub folder, it is supposed to go inside AppData\Local , AppData\LocalLow or AppData\Roaming, depending on the type of data. The most commonly used and the one used by Moi is under AppData\Roaming.
If you want to know the details on the different types of user profile data there is some info on it here:
https://www.thewindowsclub.com/local-localnow-roaming-folders-windows-10
12126.9
got a 404
EDITED: 10 Oct 6:12 by MICHAEL GIBSON
12126.10
As you can probably tell, I’m no expert when it comes to PC file structures and systems. I just want to know where the files are supposed to go. I’ve now copied in all the scripts I found, but I still can’t launch them. They ought to be in the right place by now—under C:\Users\info\AppData\Roaming\Moi\commands.
Do the file folders perhaps need to be unzipped:
12126.11 In reply to 12126.9
Hi Mala,
> got a 404
Sorry I had a typo, it's fixed now:
12126.12 In reply to 12126.10
Hi Mala,
The answer is in the first 2 sentences of the FAQ, please read it:
FAQ #1, How to install a plug-in script.
Also it can be helpful if you change a Windows setting so it will not hide the file extensions:
https://www.howtogeek.com/205086/beginner-how-to-make-windows-show-file-extensions/
Message 12126.13 deleted 10 Oct 12:35 by ZOOEN
12126.14
Hi Michael, thanks—I don't think I have issues with the file extensions; I can see whether a file is .html or .js.
New - I moved the HTML/JS files from the folders into the commands folder, but I'm still having problems. When I launch MoI, I get the error message I’ve attached, and I still can't run the scripts within the program.
Size: 115.4 KB, Downloaded: 13 times, Dimensions: 964x1165px
Message 12126.15 deleted 10 Oct 12:35 by ZOOEN
12126.16
Thanks, Zooen, for your efforts. However, I fail to see what the organization of the displayed file structure has to do with the fact that the script folder (or "commands" folder) cannot be launched from within MoI. Are we—or rather, am I—talking at cross-purposes?
Size: 135.8 KB, Downloaded: 9 times, Dimensions: 701x1107px
12126.17 In reply to 12126.14
Hi Mala,
You will get that error message on the program startup if you have placed the _Voronoi.js file in the %AppData%\Moi\startup folder.
It is not intended to be used as a startup script, it is meant to be copied into the commands folder.
If you delete the _Voronoi.js file from the startup folder that error message should stop being shown on program startup.
If you have got _Voronoi.js and _Voronoi.htm copied into the commands folder, how are you trying to run the scripts?
12126.18
Hi Michael, Voroni - Iremoved it > no more error message. Thank you.
A problem persists, however: when I click on "Scripts" in the bottom bar, the scripts in "Commands" are not triggered. Also, the "Scripts" entry appears twice.
Show messages: All  1-5  6-18
