Modlumi , IngeTrazo: Sketchups Like !
All  1-18  19-20
https://www.snaptrude.com/ Not SketchUp like but you can import SKP & Revit format!
A Bim" one with Ai ! You can have 3 projects Online but can't export anything in free!
This stair is Ai! I have drawn only the box and the 2 cylinders! :)
All the rest is Ai inside the program !
ModLumi
Take a component (or components).
Perform a single copy operation (move or rotate) and confirm the copy by pressing Enter!
Type `x7 50%`: you will end up with seven components, each reduced to half the size of the previous one!
Select the result and turn it into a component! And so on...
Since you are working with components, the possibilities are endless!
You can create wild, fractal-like structures or stunning, graphic forms!
Finally, take a screenshot of your creation, send it to your favorite AI, and ask it whatever you like!
The whole process takes less than 5 minutes!
Show messages: All  1-18  19-20
