the obj 2 dmwireframe fails
All  1  2-4
12119.2 In reply to 12119.1
Hi hadri1, it's because there aren't any polygon faces in this .obj file, it only contains line elements.
Although there are a variety of different elements listed in the .obj file spec most programs only support polygon faces. That includes obj2dmwireframe.
If you have the original source of this, does it display as a shaded object there?
12119.3 In reply to 12119.1
i asked Grok to give me a dxf from the obj file which gave me this.
Free Krea gives that from your image! You will obtain an OBJ FILe ! https://www.krea.ai/3d
You can ask model + texture but as I don't know what do you want make i just keep structure...
Not sure that is the best thing... in general redraw all on model can be more efficient! :)
As it's not specially quadrangles you must reload it inside the free Instant Mesh : https://github.com/wjakob/instant-meshes
Direct results with any regulates... :)
before subdivision Import obj BY Max Smirnov Script!
Native function SubDive : from a file : subdivision integrated!
EDITED: 1 Oct 5:56 by PILOU
Show messages: All  1  2-4
