how can I model this so that both the sides and the middle profile align with the rest of the hull? I used sweep to achive this, first selected the middle line, then the arc as a profile. moving the points of the middle line, gets me either alignment of the sides or of the center profile, not both. the main hull is a loft with only 3 curves.
I am sorry, but that is not the problem, the curves do not follow a smooth path, there is a dent in the skin, either at the bottom, or left and right, depending on the vertical curve.
ok, I will rephrase my question: how can I finish this lofted open shape, so that the end is smooth and round and has no visible division line, so that it looks like one continuous smooth object?
It's hard to give good advice just looking at a screenshot, can you please post the .3dm model file with the objects you show there?
Probably the first thing I would try would be to use Rail Revolve to make the rounded end and then have some empty space between that rounded tip and the main part and then use Construct > Blend to put in a smooth blend surface.
Or another possibility is to cut the end edge in half and then use Blend between the 2 halves.
