MultiPipe2 || SubD based implementation of Rhino's "MultiPipe" Tool for MoI
All  1-7  8-9
12116.8 In reply to 12116.7
thank you so much, great that it can be done :-)
Gabriel
EDITED: 27 Sep 1:37 by GABRIEL
12116.9 In reply to 12116.6
Hi Gabriel,
Thanks a lot for all your work. It works great!
The live preview and auto-fallback to cage curves make it way more responsive than before—almost instant.
The "Failed joints" selection works correctly in "Cage Curves," "Cage Surfaces," and "Cage Solid" modes, and it displays the problematic curves perfectly.
"Radius per style" is a very nice and smart feature. The pick button works well in simpler scenes, but in more complex cases, the point picker is a bit confusing when trying to select the correct point. However, I'm using the input field and can work with that. :)
Attached image is a test with 200 curves generated with the "Delaunay" node. I exported the low-poly cage solid into Blender. There were some parts that passed through each other, which I fixed with a smooth modifier; I also made the links and nodes a little puffier with a cloth simulation. It could have been done manually, but Blender made it simpler.
Great job, Gabriel! :)
Size: 84.4 KB, Downloaded: 7 times, Dimensions: 1310x391px
Show messages: All  1-7  8-9
