Hi MO,
Thanks, happy it helps you :)
Radii picker buttons: agreed, on more complex structures the radius picker can be confusing ( I found out that turning off snapping for that moment helps a bit).
to use mixed radii, you need to assign a different style to per curve.
When you select multiple curves, each with a different style, the script will automatically generate up to eight radii fields.
