Copy/Array in 3d?
All  1  2-3
12113.2 In reply to 12113.1
Draw your curve
And use Transform / Array Curve! ;)
here a tapered helix, but you can take any sort of curve (s)! :)
EDITED: 21 Sep 7:11 by PILOU
12113.3 In reply to 12113.1
Hi Raven, you can make the circular array oriented to a 3D axis by using View > CPlane to set the construction plane before doing the circular array.
When you set the construction plane all 2D drawing tools including array circular will be done in that orientation.
When you're done working in that area you can right click on View > CPlane to reset it back to the world axes.
Show messages: All  1  2-3
