v5 beta bug or incorrect setting by me?
12109.1
I'm running the latest v5 beta (Apr-26, 2026) but have a strange dimension problem.,
I have 2 lines, 0.1mm difference in Z, but with claiming to be the same value (in Z). Usually, you can see which is 5.5mm and which is actually 5.4mm. Is this a display bug or do I have sound rounding in my settings?
I have set the display to 2 decimal places (also tried changing to 1dp) but no difference.
Thanks!
Size: 37.4 KB, Downloaded: 15 times, Dimensions: 754x378px
Size: 34.3 KB, Downloaded: 12 times, Dimensions: 705x407px
Size: 45.7 KB, Downloaded: 7 times, Dimensions: 251x269px
12109.2 In reply to 12109.1
OK, I;m guessing buy as , when I try to move it, it shows correctly at 5.4mm
Size: 33.2 KB, Downloaded: 5 times, Dimensions: 603x268px
12109.3 In reply to 12109.1
Hi James,
Where are you looking to see the z values, is it this? :
That part of the UI shows the x,y,z coordinates of where the mouse cursor is located, it does not show the z level of selected objects.
