Object doesn't export cleanly in STP
All  1  2-3
12102.2 In reply to 12102.1
Hi Cuboctahedron, it may not like some slivery surfaces, see attached file.
What happens if before you export from Moi, select the object and run the ShrinkTrimmedSrf command (type the tab key, then type ShrinkTrimmedSrf then Enter?
I'll see if I can make a version with those slivers removed by mirroring the other half over.
12102.3 In reply to 12102.1
Try this one where the slivery faces have been removed.
Show messages: All  1  2-3
