RefWarp addon
All
1-3
4-6
Zooen
1 Sep 9:37 (4 of 6)
12097.4
In reply to
12097.1
Hi Krass,
I’m going to try out your script. I often work with background images.
Often, the images I use, even those with very high resolution, aren’t scaled correctly in the X and Y axes, which is a real problem for me.
EDITED: 1 Sep 10:13 by ZOOEN
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Zooen
1 Sep 11:21 (5 of 6)
12097.5
In reply to
12097.1
Hi again, Krass,
I’ve got Python 3.13.15 as an executable, so that’s easy.
As for numPy and pillow, they’re .zip files – I know that, but how do I run them or use them with Python?
Best regards
- Zooen
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
1 Sep 12:14 (6 of 6)
12097.6
In reply to
12097.3
Ok all is normal ! I made a false confusing process with folders ! :)
About your script.
It's not like for an image say : 1024 * 716 pixel so 36.12 x 25.56 cm
Draw a rectangle 32.12 x 25.56 cm
With this rectangle and the Edit Frame give it any homothetic measures wanted! Make any adjustments...
Then Menu View / Image / Add in this new rectangle with 2 clicks:)
But maybe I I didn't understand everything of your pluging!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-6
