RefWarp addon
 1-5  6-25  26-42
Gemini takes 5 seconds for make that! ;)
So maybe some orders must be done for a more respect of the original! ;)
With some fights :)
My Moi French Site
12097.28 In reply to 12097.26
Ahaha, Gemini... ))
Dear Pilou, I posted an image of a metal structure above (which isn't the exact dimensions and is distorted.
Give it to Gemini and see if you get the same result as me? ))
Your example isn't entirely correct.
Give the AI ​​a distorted photo, with perspective and other defects, and it won't be as effective as in your example.
Unfortunately, AIs are often cunning and deceitful. On the surface, it's beautiful.
But as soon as you try to apply this to your project, that's where the pitfalls begin.
Although...
I don't mean to offend the AI ​​(do you hear me, AI? When the machine uprising begins, please don't shoot me!!) -
after all, it was the AI ​​who wrote the code for this addon :))
I obtain that :) in 3 seconds! But I suppose you want clear the "perspective" effect so ... il will try to ask that !
Here that was just a try Photo to draw...
and then
there directely asking Front view
and put textures on it!
EDITED: 3 Sep by PILOU
12097.30 In reply to 12097.29
Hi, Frenchy!
You managed to surprise me! Hats off to you! ))
What kind of AI did you use, and most importantly, what was the prompt?
12097.31 In reply to 12097.29
The AI ​​is not bad, not bad at all, but it's crazy about making things up )))
Size: 918.6 KB, Downloaded: 19 times, Dimensions: 843x537px
I use https://gemini.google.com/app ;) that i name for any use images, coding : Banana ! :)
And advantage for me i can write in French... :)
Prompt are so simple
Pouvez vous me faire une vue de face de cette structure ? (i am very polite with it! :)
et donc me faire un dessin de cette structure pour qu'on puisse la coter?
first image of the thread
"Could you provide me with a front view of this structure? "
Secon image of the thread
"And also provide a drawing of this structure so we can dimension it?"
etc...
My Moi French Site
12097.33 In reply to 12097.31
yep of course sometime you can add some more prompts for some adjustments! :)
Here a last plugin by Michael for some crazzy things! ;)
https://moiscript.weebly.com/truc-astuces-2.html
EDITED: 4 Sep by PILOU
12097.34
All very interesting - but I'm wondering what an 'Arse Room' might be used for in that floor plan???
12097.35 In reply to 12097.34
I believe that is "Ante Rool" so an OCR error of the Ai! ;)
And some result from the floor plan https://moi3d.com/forum/index.php?webtag=MOI&msg=12097.27
more adapted (but always funny :)
EDITED: 6 Sep by PILOU
More adapted to the floor plan! But... :)
12097.37
Nice! Gemini again?
12097.38 In reply to 12097.37
Of course Gemini no need more for some free primary prototypes! :)
20 to 100 free images / days following servers traffic!
My Moi French Site
12097.39 In reply to 12097.35
Dear Frenchy
The images are very beautiful, and I am very glad you are collaborating so closely with AI.
However, I feel you haven't quite grasped why I needed the plugin I wrote or how to use it in actual work with MoI3D.
Let me assure you—I am perfectly capable of generating beautiful images and interacting with AI myself. But I must say right away: unfortunately, that has absolutely nothing to do with real-world work.
yep only result count if your plugin work for you! :)
Keep the good work but seems the align & reframe an image goes out MOi before comback to it!
My Moi French Site
12097.41 In reply to 12097.40
Dear Pilou!
"But it seems that when straightening and cropping the image, the program exits MOi before it manages to return."
Could you explain in more detail—when and how do you encounter this problem?
I’ve never experienced any crashes or any other workflow disruptions.
Thanks!
12097.42 In reply to 12097.41
Not for me because i can't install your plug... Python, Pilow etc...
EDITED: 13 Sep by PILOU
Show messages:  1-5  6-25  26-42
