RefWarp addon
All  1  2-6
you are lucky to success with ai!
I had no success with this paticular problem!
"Select rectangles automatically on the screen"! :)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.124
Michael wins the match! ;)
About your script... I have that !
it's the same ? Curves Order
My Moi French Site
12097.3 In reply to 12097.2
Hi, Pilou!
I'm afraid I'll disappoint you, but my script was written overnight last night in collaboration with Claude.
It didn't work out exactly as I wanted, but it seems to be working as expected.
Which script of yours are you referring to? Please clarify – unfortunately, I'm not familiar with it.
12097.4 In reply to 12097.1
Hi Krass,
I’m going to try out your script. I often work with background images.
Often, the images I use, even those with very high resolution, aren’t scaled correctly in the X and Y axes, which is a real problem for me.
EDITED: 1 Sep 10:13 by ZOOEN
12097.5 In reply to 12097.1
Hi again, Krass,
I’ve got Python 3.13.15 as an executable, so that’s easy.
As for numPy and pillow, they’re .zip files – I know that, but how do I run them or use them with Python?
Best regards
- Zooen
12097.6 In reply to 12097.3
Ok all is normal ! I made a false confusing process with folders ! :)
About your script.
It's not like for an image say : 1024 * 716 pixel so 36.12 x 25.56 cm
Draw a rectangle 32.12 x 25.56 cm
With this rectangle and the Edit Frame give it any homothetic measures wanted! Make any adjustments...
Then Menu View / Image / Add in this new rectangle with 2 clicks:)
But maybe I I didn't understand everything of your pluging!
Show messages: All  1  2-6
