Question about Export to STL
All  1  2-3
12090.2 In reply to 12090.1
Hi Frederick,
> So how does the export on multiple objects into one STL look in code?
If you want it to do the same as the File > Export command you would turn on selection on all the parts that you want in the same file and then call moi.geometryDatabase.fileExport( 'filename' );
If you are stuck please post the script.
12090.3 In reply to 12090.2
Thanks for the help.
You provided the information I needed.
Currently I collect all selected objects with...
var objects = moi.geometryDatabase.getSelectedObjects();
...then de-select them all.
Then I iterate over the collected objects selecting, exporting, de-selecting each one, thus getting one STL file per each initially selected objects.
So instead of selecting each one I have to decide how to identify those objects that should be exported together to the same file.
Thanks again.
Frederick
Show messages: All  1  2-3
