Boolean
All  1-9  10-18
12088.10 In reply to 12088.7
Hi Booleano,
> HI Michael
> Here it is, so you can decide what you want to do.
> Thank you very much.
Sorry, I'm not understanding what you need.
It looks like your new version there is extruding as a solid now. Is there a different problem you are still running into?
12088.11 In reply to 12088.10
Hi Michael
I have no further problems.
Thank you very much for your interest.
12088.12
As a default, if I'm going to extrude a curve, I'll check how complex its points are and usually end up rebuilding the curve anyway - making sure it's a Closed Curve. I also get cleaner results if it's flat to start with (ie occupying only 2 dimensions)
12088.13
Hi
Thank you all so much for your help, everything is sorted now
Message 12088.14 deleted 6 Sep 5:35 by BOOLEANO
12088.15
Hi
Why are there these differences in the number of points between figures "A" and "B"? Is there any way to convert figure "B" with the same number of points as figure "A", or at least approximately the same as "A", but with the points distributed similarly or equally?
Thank you.
Message 12088.16 deleted 6 Sep 6:05 by BOOLEANO
12088.17
Hi
This is the project; I replaced it because there was an error.
12088.18 In reply to 12088.15
take a curve or more then Join if only one curve needed
Press Tab , Write Rebuild
Enter nb Pts wished
etc...
My Moi French Site
Show messages: All  1-9  10-18
