functions to help select and move multiple points on a surface
12082.1
is there a way to select all the point of a given U iso line from a single point selection ? (same for V iso)
one all the point of an iso curve are selected, is there a way to move them in the U V or N direction ?
best regards,
Hadri1
12082.2 In reply to 12082.1
Hi Hadri1,
This is possible now with some script methods added in v5, see
"Update surface control point scripting." at
http://moi3d.com/forum/index.php?webtag=MOI&msg=11970.1
For expanding from a single selected point of a surface to the entire U row, paste this as the "Command" part of a shortcut key:
script: /* For any selected edit points on a surface, expand selection to entire U direction row */
var objectpicker = moi.ui.createObjectPicker();
objectpicker.allowEditPoints();
objectpicker.done();
var objects = objectpicker.objects;
for ( var i = 0; i < objects.length; ++i )
	var obj = objects.item(i);
	if ( obj.isSingleFaceBRep && obj.hasSelectedEditPoints )
		var face = obj.getFaces().item(0);
		var numu = face.numControlPointsU;
		var numv = face.numControlPointsV;
		var flag = [];
		flag.length = numv;
		for ( var v = 0; v < numv; ++v )
			for ( var u = 0; u < numu; ++u )
				var index = face.uvToEditPointIndex( u, v );
				if ( obj.getEditPointSelected( index ) )
					flag[v] = true;
					break;
			if ( flag[v] )
					obj.setEditPointSelected( index, true );
This one for V:
script: /* For any selected edit points on a surface, expand selection to entire V direction column */
		var flag = [];
		flag.length = numu;
					flag[u] = true;
					break;
			if ( flag[u] )
Sorry no, not currently.
