Modify Command Behavior With Key Held Down
All  1-3  4-8
12080.4 In reply to 12080.2
Tried you code and it worked fine.
I was thinking that it might be able to check/uncheck the "Both Sides" box (and similar things) in the dialog by using/not using a key
Cannot be done?
Frederick
12080.5 In reply to 12080.4
Hi Frederick,
> Cannot be done?
A command can register a shortcut key and then do something when that key is pressed. See attached example where typing the B key works the same as clicking on "Both sides".
But it works like other shortcut keys under Options > Shortcut keys, you can't do something when the key is pressed and something different when the key is released.
12080.6 In reply to 12080.5
So when the dialog is first display there is no point at which the state of the control/shift/alt key can be detected and check (or uncheck) a checkbox that is part of the dialog?
Frederick
12080.7 In reply to 12080.6
Hi Frederick,
Nope, not from script.
12080.8 In reply to 12080.7
Hi Michael.
Understood about the limitation of script.
I was thinking of my general windows programming tool and all mouse events report the state of the mouse buttons AND control/shift/alt.
Frederick
Show messages: All  1-3  4-8
