Curvature Combs
All  1-3  4-8
You have my little Zebra prog! ;)
Import export Iges ;)
https://moiscript.weebly.com/zebra.html
My Moi French Site
12077.5 In reply to 12077.3
Barry,
Thanks for the neat idea...I've never used the node editor in MOI and have got it somewhat working as per your screen grab.
Couple of questions if you don't mind...
1, how did you connect the one selected curve to 2 outputs...for me it either one or the other.
2, After adjusting the points on my curve, is it expected to manually update the 'selected' node with right click? or is there an automatic way for the generated Comb to update itself?
Cheers, and thanks!
Toby
12077.6 In reply to 12077.5
Hi Toby,
You must be using an old version of the nodeditor so you need to use the clone node to get the 2 outputs.
There’s a new version of the nodeditor on forum would suggest you find that.
Unless you create the curves within the nodeditor you will need to run it every time.
If you create the curve points within the nodeditor they can be moved ( X & Y ) with nodes
thus the curvature comb will update as you modify them.
Hope that make sense.
Barry
12077.7 In reply to 12077.6
Hi Barry,
I'm using the 1.1 version...think it's the same one as shown in your screen capture.
I'll have a further look around.
Cheers,
Toby
12077.8 In reply to 12077.7
hi Toby,
here is the link to the latest nodeditor plus https://moi3d.com/forum/index.php?webtag=MOI&msg=11614.1
Barry
Show messages: All  1-3  4-8
