Line divide tool
All  1-5  6-9
12072.6 In reply to 12072.3
Hi Michael.
Yes, as an extra trim command option that could/would be extremely useful/welcome.
There will be a time when I use curves more but for now I'm very much on straight lines!
MoI of course is really powerful on curves, and surfacing using curves but it slightly lacks in the more boring (!) straight line department which is a bit of a shame.
I think I just hung on with SketchUp for too long, after (industrial engineering design) training using Solidworks/Pro-Engineer both of which weren't then as hot on surfacing. I don't know what either latter are like now as I haven't used either in so long.
But often when drawing or designing enclosures, bot small box-sized, or much bigger house-sized projects (I've done loft conversion projects for architects requiring modelled examples to show to clients etc), being able to split a line into equal sections is very useful.
I hope that makes sense.
Tom
12072.7 In reply to 12072.5
Tom.
MoI almost has this feature under Construction Lines > Division snap. Maybe the feature you want could be added there.
Martin.
12072.8 In reply to 12072.7
Hi Martin.
Yes, possibly. But wherever it is placed it shouldn't get in the way of the already elegant interface. Ease of use of course, being key.
Tom
Hi Tom,
Did you have tested the ReconstructCurve script ?
Two ways to use it, but I think you could use it by launch it, choose your line and the PolyLine method.
The result is a polyline with your choosen number of parts.
If you select your line and next launch ReconstructCurve, you will have a soft curve with your choosen number of parts.
To find This script, you can search in Ressources of the site.
Show messages: All  1-5  6-9
