Line divide tool
All  1  2-7
12072.2 In reply to 12072.1
Actually I've just discovered another workaround that could I suppose be scripted (need to learn how to script!)
Draw a line, then draw another line 90ยบ perpendicular to the first, select that and use the directional array tool, choose the amount of segments, then left-click again at the end of the original line. Then use the trim tool to break out into segments. What palaver! But it does work. A script to do all this, then clean up afterwards would be acceptable, but I'd rather have a script baked into an actual tool! ;0)
Tom
12072.3 In reply to 12072.1
Hi Tom, I guess it may just not come up as often in MoI as in SketchUp because usually you're working with curves in MOI while SketchUp works on polygons and polylines.
Is there a particular kind of project where it's helpful to have this?
In SketchUp does it only do this on a single line, not a whole polyline?
Maybe I could incorporate this better into MOI as an option in the Trim command.
Hi Tom,
What do you want to have as result ?
You have simple line and you want as result a PolyLine or you want a line with N points which will be an object typed curve ?
Could you post an example of what you want ?
12072.5 In reply to 12072.4
I want a simple straight line cut into any amount of segments of equal lengths. No 'Object typed curves' etc needed here!
I've worked out how to do it, but it's a faff (see second post)
Needs a tool. Or a good script.
12072.6 In reply to 12072.3
Hi Michael.
Yes, as an extra trim command option that could/would be extremely useful/welcome.
There will be a time when I use curves more but for now I'm very much on straight lines!
MoI of course is really powerful on curves, and surfacing using curves but it slightly lacks in the more boring (!) straight line department which is a bit of a shame.
I think I just hung on with SketchUp for too long, after (industrial engineering design) training using Solidworks/Pro-Engineer both of which weren't then as hot on surfacing. I don't know what either latter are like now as I haven't used either in so long.
But often when drawing or designing enclosures, bot small box-sized, or much bigger house-sized projects (I've done loft conversion projects for architects requiring modelled examples to show to clients etc), being able to split a line into equal sections is very useful.
I hope that makes sense.
Tom
12072.7 In reply to 12072.5
Tom.
MoI almost has this feature under Construction Lines > Division snap. Maybe the feature you want could be added there.
Martin.
Show messages: All  1  2-7
