Line divide tool
 1-18  19-23
12072.19
Using the Line tool, stretch a construction line over the line you want to divide. Use the Division snap option and enter your number of divisions (say 10). Go to division snap No1 and start your line. End it at the beginning of the original line. Delete the original line. This leaves you with a line one tenth the length of the original, which you can now Array.
I hope this makes sense. ;-)
Martin.
12072.20 In reply to 12072.17
THe PointsOnAdaptiveCurve command has an option you can select to "Convert to polyline"
A smart fellow could probably copy that command then remove the "create points" part and just end up with a divided polyline with one command.
12072.21 In reply to 12072.17
I'll have the Kidney with a mashed Fava Bean Salad with a Ricotta spread on Naan!
12072.22 In reply to 12072.21
Wow, I knew MoI could do lots of good stuff, but... ;-}
--Larry
12072.23 In reply to 12072.22
MoI can Upscale Hannibal Lecter on culinary choices….
And the guy DID offer his kidney to anyone with a solution and not a trimming workaround!
EDITED: 14 Aug 19:41 by BURRMAN
Show messages:  1-18  19-23
