New Section command
 1  2-21  22-41  42-49
12071.42 In reply to 12071.41
Hi PIlou,
> But it's only one color for all the surfaces and not each separately!
You can do it separately if you run the Section command 3 separate times and only generate one section each time.
You can also set up a keyboard shortcut that will enable just one specific plane at a time, like this:
Section UseXY=true UseXZ=false UseYZ=false
12071.43 In reply to 12071.41
@Pilou, it's also possible to automatically set a specific style to be the active style in a shortcut key as well, like this:
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Rouge' ); moi.geometryDatabase.activeStyle=style.index;" UseXY=true UseXZ=false UseYZ=false
If you set that on a shortcut key when you press it, it should set the XY checkbox to be on, XZ and YZ checkboxes off and make a style named 'Rouge' to be the active style.
12071.44 In reply to 12071.43
Yep so if i good understand I must have 3 different shortcuts! :)
Something like
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Vert' ); moi.geometryDatabase.activeStyle=style.index;" UseXZ=true UseYX=false UseYZ=false
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Bleu' ); moi.geometryDatabase.activeStyle=style.index;" UseYZ=true UseXY=false UseXZ=false
Yep but that is just successively ! :(
If i add a true there is 2 same colors!
EDITED: 13 Aug 17:18 by PILOU
12071.45 In reply to 12071.44
Yes that's correct.
Sorry I don't understand this part.
12071.46 In reply to 12071.45
on my video above on the last image there 2 red planes because I add a "true" condition!
I can't have the 3 different colors in the same time !
My Moi French Site
12071.47 In reply to 12071.46
Yes that's correct, this command is not designed to make 3 different colors at the same time.
Is that something that you need to do frequently?
12071.48 In reply to 12071.47
No aespecially but seems to me that will be just natural that "pushing" a section will show that you are in a primary axis (red , green , blue)
EDITED: 13 Aug 17:46 by PILOU
12071.49 In reply to 12071.48
@Pilou,
> No aespecially but seems to me that will be just natural that "pushing" a surface
To me that seems like it would be distracting. seeing a big red surface would seem to me like a "danger something's wrong" signal.
Show messages:  1  2-21  22-41  42-49
