New Section command
 1-15  16-35  36-49
12071.36
The dimension tab could also be a good spot for this command.
Marc
12071.37
Wow - seriously useful command!
Up till now I've been making copies of solids & slicing them up in different ways to get an idea of what's going on - this has made things way easier.
It's sometimetimes a little glitchy depending on complexity/number of solids, but that might just be my processor, and it gets there in the end ;)
Kudos to whoever came up with this!
12071.38 In reply to 12071.37
777RAVEN777
"Kudos to whoever came up with this!"
Rich asked and Michael delivered. ;-)
Seems we can't give a color to the section(s) surface(s) during the process!
(or before in giving different colors to the surfaces' volumes like X= Red, Y = Green, Z = Blue)
EDITED: 13 Aug by PILOU
12071.40 In reply to 12071.39
Hi Pilou, in "Section plane" mode, the generated plane will get the "active style" applied to it.
Go to the scene browser styles section and right click on a style's color swatch to set it as active.
12071.41 In reply to 12071.40
Yep cool trick for give a color!
But it's only one color for all the surfaces and not each separately!
Sure I can at the exit of the function but...
My Moi French Site
12071.42 In reply to 12071.41
Hi PIlou,
You can do it separately if you run the Section command 3 separate times and only generate one section each time.
You can also set up a keyboard shortcut that will enable just one specific plane at a time, like this:
Section UseXY=true UseXZ=false UseYZ=false
12071.43 In reply to 12071.41
@Pilou, it's also possible to automatically set a specific style to be the active style in a shortcut key as well, like this:
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Rouge' ); moi.geometryDatabase.activeStyle=style.index;" UseXY=true UseXZ=false UseYZ=false
If you set that on a shortcut key when you press it, it should set the XY checkbox to be on, XZ and YZ checkboxes off and make a style named 'Rouge' to be the active style.
12071.44 In reply to 12071.43
Yep so if i good understand I must have 3 different shortcuts! :)
Something like
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Vert' ); moi.geometryDatabase.activeStyle=style.index;" UseXZ=true UseYX=false UseYZ=false
Section oncommandstart="var style=moi.geometryDatabase.findStyle( 'Bleu' ); moi.geometryDatabase.activeStyle=style.index;" UseYZ=true UseXY=false UseXZ=false
Yep but that is just successively ! :(
If i add a true there is 2 same colors!
12071.45 In reply to 12071.44
Yes that's correct.
Sorry I don't understand this part.
12071.46 In reply to 12071.45
on my video above on the last image there 2 red planes because I add a "true" condition!
I can't have the 3 different colors in the same time !
My Moi French Site
12071.47 In reply to 12071.46
Yes that's correct, this command is not designed to make 3 different colors at the same time.
Is that something that you need to do frequently?
12071.48 In reply to 12071.47
No aespecially but seems to me that will be just natural that "pushing" a section will show that you are in a primary axis (red , green , blue)
12071.49 In reply to 12071.48
@Pilou,
> No aespecially but seems to me that will be just natural that "pushing" a surface
To me that seems like it would be distracting. seeing a big red surface would seem to me like a "danger something's wrong" signal.
Show messages:  1-15  16-35  36-49
