New Section command
 1-4  5-24  25-32
Threads Merged: This thread was merged from here
12071.25 In reply to 12071.21
> What is the use of this Point ?
When you push that you can then pick a point on the model and the section cutting plane will pass through that point.
Here is an example using that option to make the plane pass directly through a corner on the model:
12071.26 In reply to 12071.24
Hi Martin, thank you very much for your feedback! :)
It turned out that I had a good space to include those controls after moving the slider to its own line.
That adds a lot of flexibility being able to use one tool for both visual analysis and also geometry construction.
I'm thinking maybe it could get an icon on the View tab in the side pane, what do you think? CPlane is there and seems related.
12071.27 In reply to 12071.25
Thx for the info!
My Moi French Site
12071.28 In reply to 12071.26
Michael.
Adding an icon to the tool palette would be the cherry on the cake as far as I'm concerned and I can't think of a better place than the one you suggested, so it's a thumbs up from me.
Thank you.
Martin.
EDIT: This tool is also useful for creating new planes. Just create the sections as required under 'Section plane', tick 'Keep geometry', followed by 'Done' and then use the CPlane tool on this geometry. If you now press the 'Undo' button, then your solid comes back, but the CPlane stays in its new position. ;-)
EDITED: 10 Aug 8:46 by BLOWLAMP
12071.29
Fantastic tool!
Maybe it could live in the "view" Tab ?
Marc
Very impressive function.
I don't know how I will use it and exploit this potential but I will find...
I have questions :
When I select a surface of a solid or joinedSurf and use "Section", MoI respond "Select solids to section". --- > Normal
When I select a curve and use "Section", MoI respond "Select solids to section". --- > Normal
When I select a lonely single surface and use "Section", MoI respond with an error :
TypeError: undefined is not an object (evaluating 'bbox.center.x')
Section.js line 87
MoI avoid the view of the surface (not deleted but not visible since moved or save/reload.
Is it possible that MoI respond with "Select solids to section"
And when I use "Section" on a joined surface, the result could be strange because MoI have problems to know how to cut.
Perhaps could You limit the use of Secition only on solid and deny all other type of objects ?
EDITED: 10 Aug 14:19 by PHIRO
12071.31 In reply to 12071.26
"""""""""""""""I'm thinking maybe it could get an icon on the View tab in the side pane"""""""""""
Cyrus says "I can dig it!"
12071.32
Thanks for the section command. It is a useful tool indeed. Often, I find myself drawing a straight line in one of the parallel views, then using that line to generate a projected curve on my objects for cutting faces or detailing. This requires some trial and error to get the best result.
I am wondering if it is possible to have the "Section Plane" outlines generate pseudo-projected lines on objects, as these results are much cleaner than standard projected lines. I believe an "outline" mode would be a great fit for this command.
Additionally, if you agree that an "outline" mode would be beneficial, it would be useful to have a way to retain both the object and the section outputs, as they can be used to construct curves for further modeling.
options such as: [None, Keep Section Geometry, Keep All].
Show messages:  1-4  5-24  25-32
