Some things small for the version 5 wish list
All  1-6  7-9
12055.7 In reply to 12055.5
Hi Zooen,
> I just tested it. This addition does indeed seem useful if you use Flow a lot.
> What do you think, Michael?.
There needs to be a setting for which commands to have history updating turned on by default. In the meantime if you want Flow to have history updates turned on by default you can make that happen now with what shayne shows above.
12055.8 In reply to 12055.6
Hi Frederick,
> Just out of curiosity what does/would your addition do?
It turns on history updates for the output objects. The same as selecting the result objects and clicking Edit > History > "Enable update".
When history updating is turned on with Flow you can edit the base or target curves that were used by Flow and the Flow will be automatically reapplied.
Yep that is some funny tool! :) whith history on ! ;) manually or by the new script above)
Show messages: All  1-6  7-9
