Tracing solid perimeter
All  1-5  6
12048.6 In reply to 12048.5
Hi fcwilt,
The “ExtendEdgeSelection” script allows you to select all edges starting from a single edge on certain faces of solids or surfaces. It works for your part because it has no corners. For parts with corners, you can adjust the first parameter: “var angle_degrees = 20;” to suit your needs.
With the attached file, you can test the green part using the default value of 20.
Select the designated edge and run the script; this will select 3 edges. If you replace the value 20 with 90 (and save), you’ll select all the edges on the top face of the solid. You’ll need to close MoI and restart it for this to work. I use Notepad++
Well, Michael will explain all this more clearly than I can. I have very little knowledge of scripts, so I often work by trial and error.
Oops, I forgot the sample file
Warning! Translation from French using DeepL Pro
EDITED: 24 Jul 7:31 by ZOOEN
Show messages: All  1-5  6
