Hi Frederick,
> The != below IS case sensitive
Yes, for example if you run this script:
moi.ui.alert( 'test' != 'Test' );
result is: 'true'
> The function below IS NOT case sensitive
> vp.reverseView( vname )
Yup.
> So is there a function to compare two strings that is not case sensitive OR has
> an additional parameter that chooses between being case sensitive or not?
There is. Try doing a web search for "javascript string compare ignore case", there is a whole lot of information online about Javascript language functions.
