Script question
All  1-15  16-18
12047.16 In reply to 12047.15
Thanks for the info.
Let me see if I have this all now:
The != below IS case sensitive
vp.getViewport(vname).name != vname
The function below IS NOT case sensitive
vp.reverseView( vname )
So is there a function to compare two strings that is not case sensitive OR has an additional parameter that chooses between being case sensitive or not?
Frederick
12047.17 In reply to 12047.16
Hi Frederick,
Yes, for example if you run this script:
moi.ui.alert( 'test' != 'Test' );
result is: 'true'
Yup.
There is. Try doing a web search for "javascript string compare ignore case", there is a whole lot of information online about Javascript language functions.
12047.18 In reply to 12047.17
You are the best.
Frederick
Show messages: All  1-15  16-18
