Splitting an object into two
All  1-4  5-8
12046.5 In reply to 12046.4
Fantastic! Thanks Pilou! Perfect.
12046.6 In reply to 12046.5
Press "Keep object" if you want 2 objects! ;)
My Moi French Site
12046.7 In reply to 12046.3
""""""""""but would you be a little more specific on how best to use the boolean tool here for solids?""""""""""
This should have the little nugget you were looking for!
A cool function can be the Native ExplodeMove after a multiple Boolean (Merge here) ! ;)
Voronoi for the perpendicular faces!
Boolean Merge the 2 perpendicular planar curves
then ExplodeMove as shortCut or Press Tab and write ExplodeMove
Of course ExplodeMove will work also with some Boolean Diff! ;)
EDITED: 21 Jul 19:58 by PILOU
Show messages: All  1-4  5-8
