Splitting an object into two
All  1-2  3-8
12046.3
I've no scripts installed yet, but would you be a little more specific on how best to use the boolean tool here for solids?
I've been using booleans an awful lot since buying MoI3d a few days ago.
Fantastic software MoI3d is, I'm still learning! Better than... cough... Rhino IMHO (even though Michael 'invented' that too!)
Boolean DIff ?
Right Click for Done
Click Volume not wanted
Press Key Delete (or red X) for kill line + volume not wanted in the same time!
For a cylinder take a diameter! ;)
For a complex object take a plane (or an extruded line/curve )
EDITED: 21 Jul 15:33 by PILOU
12046.5 In reply to 12046.4
Fantastic! Thanks Pilou! Perfect.
12046.6 In reply to 12046.5
Press "Keep object" if you want 2 objects! ;)
My Moi French Site
12046.7 In reply to 12046.3
""""""""""but would you be a little more specific on how best to use the boolean tool here for solids?""""""""""
This should have the little nugget you were looking for!
A cool function can be the Native ExplodeMove after a multiple Boolean (Merge here) ! ;)
Voronoi for the perpendicular faces!
Boolean Merge the 2 perpendicular planar curves
then ExplodeMove as shortCut or Press Tab and write ExplodeMove
Of course ExplodeMove will work also with some Boolean Diff! ;)
EDITED: 21 Jul 19:58 by PILOU
Show messages: All  1-2  3-8
