Splitting an object into two
All  1  2-8
12046.2 In reply to 12046.1
Boolean for solids
Trim for surfaces
Both will use “projection” with the cutter so it doesnt need to be placed “on” the obect.
There is also an old “quick split” scripts that will quickly divide objects like that
12046.3
I've no scripts installed yet, but would you be a little more specific on how best to use the boolean tool here for solids?
I've been using booleans an awful lot since buying MoI3d a few days ago.
Fantastic software MoI3d is, I'm still learning! Better than... cough... Rhino IMHO (even though Michael 'invented' that too!)
Boolean DIff ?
Right Click for Done
Click Volume not wanted
Press Key Delete (or red X) for kill line + volume not wanted in the same time!
For a cylinder take a diameter! ;)
For a complex object take a plane (or an extruded line/curve )
EDITED: 21 Jul 15:33 by PILOU
12046.5 In reply to 12046.4
Fantastic! Thanks Pilou! Perfect.
12046.6 In reply to 12046.5
Press "Keep object" if you want 2 objects! ;)
My Moi French Site
12046.7 In reply to 12046.3
""""""""""but would you be a little more specific on how best to use the boolean tool here for solids?""""""""""
This should have the little nugget you were looking for!
A cool function can be the Native ExplodeMove after a multiple Boolean (Merge here) ! ;)
Voronoi for the perpendicular faces!
Boolean Merge the 2 perpendicular planar curves
then ExplodeMove as shortCut or Press Tab and write ExplodeMove
Of course ExplodeMove will work also with some Boolean Diff! ;)
EDITED: 21 Jul 19:58 by PILOU
Show messages: All  1  2-8
