V5 beta startup folder
All  1-4  5-7
12040.5 In reply to 12040.4
Hi dune1982,
> Is there a way now to make MoI not chache the files on startup. Currently I have to restart
> MoI on every change in a file. I know there was a section in the moi.ini but i was not able
> to find it in V5
On http://moi3d.com/wiki/Scripting look for:
"See here for info on disabling file caching so commands will reload on every run"
> \Users\<user>\AppData\Roaming\Moi\plugins\<myplugin> where should i put
> my EnglishStrings.txt file so MoI can find it?
Currently MoI will only load string tables from the install's UI folder so there isn't a way to deploy your own string table in a plugin.
So in your .htm files don't use <moi:Text textid=""/> which looks up text in the string table, instead just put in your text directly.
So like this:
<moi:CommandButton>Text</moi:CommandButton>
Instead of this:
<moi:CommandButton><moi:Text textid=""/></moi:CommandButton>
EDITED: 22 Jul by MICHAEL GIBSON
12040.6 In reply to 12040.5
Ok so to make it multilingual, i have to come up with my own solution or put my strings in the original txt files.
See attached the section of my moi.ini, there is no DisableFileCaching
Size: 70.5 KB, Downloaded: 23 times, Dimensions: 979x461px
12040.7 In reply to 12040.6
Hi dune1982,
You need to add in that line.
Show messages: All  1-4  5-7
