Flipping an object
12035.1
Hi group!
What is the most reliable and consistent way to flip an object (upside-down)?
I'm using the v4 trial version, not the v5 beta.
So far I can only seem to rotate. I have had a few times where the solid has moved 90º, but to get a 180º flip I'm not winning here.
12035.2
If you have straight snap toggled on the bottom task bar when you grab the object rotate widget in view it will snap to 90 and 180 when you rotate it
You have also this transformation... depending of what do you want...
use other windows than 3D !
Result in real time in the 3D window !
EDITED: 1 Jul 7:11 by PILOU
12035.4 In reply to 12035.1
Transform > Mirror might be what you want.
- Peer
