started with
"generate a 5x5 pocket with a .5 endmill outside to center coordinates text file""
google respnse
A 5x5-inch square pocket centered at X0, Y0 with a 0.5-inch endmill requires a 5.5-inch total programmed width to account for the tool's diameter on the outside edges. The stepover is typically set to 40% (0.2 inches) to clear the material.
Paste the following coordinate file (saved as a .txt or .nc file) into your conversational CNC software or CAD/CAM post-processor to generate the pocket:
google ai has an "ask anything right below its responses now
next i enter
"remove all gcode values"
response is
Here are the raw coordinates for a 5x5-inch square pocket using a 0.5-inch endmill, formatted as pure text with all G-codes, line numbers, and remarks removed.
The coordinates trace the toolpath from the outermost boundary (-2.75 to +2.75) inward to the center at X0, Y0, using a 0.2-inch stepover:
Next i enter
"spiral pocket"
and the response
Here are the raw coordinates for a 5x5-inch square pocket using a 0.5-inch endmill, formatted as a continuous inward spiral.
This toolpath starts at the outermost top-left corner (-2.75, 2.75) and spirals tightly inward toward the center (0,0) using a 0.2-inch stepover, keeping constant tool engagement:
last ask
"remove all x and y"
and the response which generated the attached file
Here are the raw coordinates for the spiral pocket with all letters, spaces, and G-codes removed, leaving only the bare numeric values:
