Spiral following an outline inside a closed curve
All  1-4  5-8
12030.5 In reply to 12030.4
Thanks Michael,
a good idea with the diagonal lines for the example (rectangle).
The problem is that I'm looking for a solution that is also working for closed curves that were designed with a Freeform line. Here the the line behind the outline needs to be a child of the outline. Next line needs to be a child of the first child, etc.
I had in mind that such a function was/is existing in MoI or as script from Max Smirnov.
But thanks a lot for your trying to find a solution,
Joerg
12030.6 In reply to 12030.5
Hi Joerg,
Do you have an example drawing of this type?
There is an OffsetMultiStep script here:
https://moi3d.com/forum/index.php?webtag=MOI&msg=4898.19
But it isn't very much like a continuous spiral.
12030.7 In reply to 12030.5
If you can figure out how to get the coords for your path, you can use a point file and import point file as polylines to generate the path
12030.8 In reply to 12030.7
Maybe with more discussion we can get a result for you.
Like basically these points can be generated easily by my CAM software with a pocketing operation
Must be a bunch of free options available to do this
There is even a guy in this forum trying to develop a "toolpath" plugin!
Show messages: All  1-4  5-8
