Spiral following an outline inside a closed curve
All  1-15  16-19
12030.16 In reply to 12030.15
mostly outputs are rubbish.
Had better luck making progress with GROK and prompts to change its output. Still sortof painful to be any type of real solution for what you are asking...
12030.17 In reply to 12030.16
Thank you for your efforts on this. It appears this task cannot be completed quickly using standard MoI tools. However, Michael showed a MoI-script that reduces the workload by helping to create the spiral manually.
The exploration of CAM was an interesting idea, though mine was unfortunately unable to generate the required construct in this case.
Ultimately, it seems that performing this task with standard tools is difficult without custom coding. Unless this is a task we need to perform daily, the manual script solution likely remains the most efficient approach.
BR, Joerg
12030.18 In reply to 12030.17
Hey Joerg,
Not for lack of trying, eh!
Looked at my CAM software. What we are doing is called a “morph spiral” and its more complex for sure.
It was a good exercise looking at how ai failed with the “more complex” parts of the solve. It definitely highlighted what the “complex” part is. Thats where rubbish was returned
Happy trails….
12030.19 In reply to 12030.18
Hi Joerg,
1 last note. A side note.
Thought about it more and vector programs can do this pretty easily. So draw a spiral then “fit it to another shape” basically.
Just in case you can do that as an option
Show messages: All  1-15  16-19
