Spiral following an outline inside a closed curve
All  1-9  10-15
12030.10 In reply to 12030.9
started with
"generate a 5x5 pocket with a .5 endmill outside to center coordinates text file""
google respnse
A 5x5-inch square pocket centered at X0, Y0 with a 0.5-inch endmill requires a 5.5-inch total programmed width to account for the tool's diameter on the outside edges. The stepover is typically set to 40% (0.2 inches) to clear the material.
Paste the following coordinate file (saved as a .txt or .nc file) into your conversational CNC software or CAD/CAM post-processor to generate the pocket:
google ai has an "ask anything right below its responses now
next i enter
"remove all gcode values"
response is
Here are the raw coordinates for a 5x5-inch square pocket using a 0.5-inch endmill, formatted as pure text with all G-codes, line numbers, and remarks removed.
The coordinates trace the toolpath from the outermost boundary (-2.75 to +2.75) inward to the center at X0, Y0, using a 0.2-inch stepover:
Next i enter
"spiral pocket"
and the response
Here are the raw coordinates for a 5x5-inch square pocket using a 0.5-inch endmill, formatted as a continuous inward spiral.
This toolpath starts at the outermost top-left corner (-2.75, 2.75) and spirals tightly inward toward the center (0,0) using a 0.2-inch stepover, keeping constant tool engagement:
last ask
"remove all x and y"
and the response which generated the attached file
Here are the raw coordinates for the spiral pocket with all letters, spaces, and G-codes removed, leaving only the bare numeric values:
EDITED: 24 Jun 16:16 by BURRMAN
12030.11 In reply to 12030.10
So the next question is can you provide the search with your "custom shape", closed contour, and generate the same results!
12030.12 In reply to 12030.11
The result
12030.13 In reply to 12030.6
I think the OffsetMultiStep script was the script I had in mind, reading about it more than 10 years ago. But I thought that this one would create a spiral...
But I tested the script and it is helping a lot to create a bunch of curves, especially when the number of curves gets double-digit or more.
I attached an example of a non-standard outline created with the Freeform tool.
BR
Joerg
12030.14 In reply to 12030.11
Hi BurrMan,
using a CAM software is a good idea if the software is able to create a bare spiral. I followed your proposal and tested different toolpaths created by different milling strategies. The best result is attached (blue lines). But the CAM software is not creating a spiral and is automatically doing S-linking between the different offset lines. There is no option to get the CAM not doing that.
BR, Joerg
Size: 456.9 KB, Downloaded: 11 times, Dimensions: 1437x972px
12030.15 In reply to 12030.14
you'll need to be able to do some type of spiral pocketing. I think my software has it. I'll have to go crank it up and look in a few.
The ai is tricky to prompt to get results. Because it is actually a "Morph Spiral". Not just a standard pocket or boundary pocket
Here is me attempting to get results with your file
Started with to proper path
then tried to get more "revolutions"
Finally made it all the way to center with revolutions and lost ability to control step
Its getting complex
Show messages: All  1-9  10-15
