Spiral following an outline inside a closed curve
12030.1
I am looking for an efficient way to create a spiral that follows the inner outline of a closed curve with a defined distance between the lines.
For example, starting from the upper-left corner of a rectangle, the spiral would follow the shape’s interior outline, continuing inward turn by turn at a specific offset distance.
Could you suggest a method or tool to achieve this?
Joerg
12030.2 In reply to 12030.1
Hi Joerg,
Can you make a rough sketch of it?
12030.3 In reply to 12030.2
Thanks for your message!
I attached an example with a simple rectangle as closed curve and created the spiral manually with the Offset function, added short connection lines, trimmed the offset rectangles and joined the lines to a single spiral curve.
Cheers,
Joerg
12030.4 In reply to 12030.3
Hi Joerg, so kind of like the snake or Tron lightcycle games where a path is grown leaving a trail behind which you don't want to run into?
Is it required that the closed curve must be made of line segments and not a continuous smooth curve? What if the closed curve is a circle for example?
One thing I noticed is if you put in diagonal lines like this:
Move the diagonal for the start down one step, a quick way to do this is to type 20 and push Enter, that will make a distance constraint active for the next point pick and then you can drag the line down one step:
You now have all the necessary structure to draw the spiral in one single polyline. Before placing the first polyline point type in r20,-20 and push Enter. That will enable an x,y offset to be applied to the next point pick:
From then on straight snap and intersection object snap will give the needed points:
12030.5 In reply to 12030.4
Thanks Michael,
a good idea with the diagonal lines for the example (rectangle).
The problem is that I'm looking for a solution that is also working for closed curves that were designed with a Freeform line. Here the the line behind the outline needs to be a child of the outline. Next line needs to be a child of the first child, etc.
I had in mind that such a function was/is existing in MoI or as script from Max Smirnov.
But thanks a lot for your trying to find a solution,
Joerg
