一个想法(an idea)
All  1  2-3
12027.2 In reply to 12027.1
Hi SUIYAN,
It is possible to set the title="" property on command buttons with script like this:
function SetButtonTitle( button )
	button.title = 'the title';
var panels = moi.ui.getUIPanels();
for ( var i = 0; i < panels.length; ++i )
	var panel = panels.item(i);
	var buttons = panel.document.getElementsByTagName( 'moi:CommandButton' );
	for ( var j = 0; j < buttons.length; ++j )
		SetButtonTitle( buttons[j] );
But the part that may be tricky is that any buttons on popup menus, dialog windows, or command sets will only be accessible after the menu/dialog/whatever is displayed.
12027.3 In reply to 12027.1
and the shortcut keys can be accessed by script like this: (Moi v4+ required):
var shortcuts = moi.shortcutKeys.getShortcuts();
for ( var i = 0; i < shortcuts.length; ++i )
     var shortcut = shortcuts.item(i);
      var key = shortcut.key;
      var command = shortcut.command;
      moi.ui.alert( key + ' ' + command );
Show messages: All  1  2-3
