一个想法(an idea)
12027.1
HI EveryOne
将moi.ini文件中的快捷键映射于相对应的工具按钮的鼠标停靠文字(Map the shortcut keys in the moi.ini file to the corresponding tool button mouse-over text),我掌握的方法用<moi:CommandButton title="shortcut key",但这样当快捷键发生修改时,鼠标停靠文字无法动态更新。能否通过脚本或代码,直接将moi.ini文件中快捷键的部分直接显示为鼠标停靠文字?
(The method I have mastered uses "<moi:CommandButton title="shortcut key"", but when the shortcut key is modified, the mouse hover text cannot be dynamically updated. Is it possible to use a script or code to directly display the shortcut key from the moi.ini file in the mouse hover text of the corresponding tool button?)
最好适用于v3+谢谢(Best for v3+ ,Thanks)
EDITED: 21 Jun 3:46 by SUIYAN
12027.2 In reply to 12027.1
Hi SUIYAN,
It is possible to set the title="" property on command buttons with script like this:
function SetButtonTitle( button )
	button.title = 'the title';
var panels = moi.ui.getUIPanels();
for ( var i = 0; i < panels.length; ++i )
	var panel = panels.item(i);
	var buttons = panel.document.getElementsByTagName( 'moi:CommandButton' );
	for ( var j = 0; j < buttons.length; ++j )
		SetButtonTitle( buttons[j] );
But the part that may be tricky is that any buttons on popup menus, dialog windows, or command sets will only be accessible after the menu/dialog/whatever is displayed.
12027.3 In reply to 12027.1
and the shortcut keys can be accessed by script like this: (Moi v4+ required):
var shortcuts = moi.shortcutKeys.getShortcuts();
for ( var i = 0; i < shortcuts.length; ++i )
     var shortcut = shortcuts.item(i);
      var key = shortcut.key;
      var command = shortcut.command;
      moi.ui.alert( key + ' ' + command );
