How would I orient a single window?
All  1-2  3-4
12021.3 In reply to 12021.2
hi ado,
was going to say that...
i think the inventor of this software made it inspirational
because day by day we are finding things.
anyway, also i'll try find you some of michaels viewport controls that i love
and use personally as shortcuts (on the numpad keys)...
now below:
EDITED: 14 Jun 8:00 by LIGHTWAVE
12021.4 In reply to 12021.3
Hi Ado, these are my viewport shortcuts, to me they are logical
Numpad. [dot] =
script:moi.ui.mainWindow.viewpanel.mode = '3D'; var vp = moi.ui.mainWindow.viewpanel.getViewport('3D'); if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.reset(); }
Numpad0=
script: /* SPLIT! */ moi.ui.mainWindow.viewpanel.mode = 'Split'; if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { moi.view.resetAll(); }
Numpad1=
script:var vname = 'Top'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad2=
script:var vname = 'Front'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad3=
script:var vname = 'Right'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad4=
script:var vname = 'Bottom'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad5=
script:var vname = 'Back'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad6=
script:var vname = 'Left'; var vp = moi.ui.mainWindow.viewpanel; vp.mode = vname; if ( vp.getViewport(vname).name != vname ) { vp.reverseView( vname ); } if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { vp.getViewport(vname).reset(); }
Numpad* [asterix] =
script:moi.ui.getActiveViewport().reset();
To add shortcuts and assign these viewport scripts to your shortcut keys, use:
options>shortcut keys>add
press a key like numpad 1 and then paste:
repeat.
cheers stefano
there is also a shortcut script to "add shortcut"
with this script:
https://moi3d.com/forum/index.php?webtag=MOI&msg=12006.1
EDITED: 14 Jun 9:10 by LIGHTWAVE
Show messages: All  1-2  3-4
