Command Palette Search Commands & Scripts Fast ⚡
All  1-6  7-11
12014.7 In reply to 12014.6
I do not use allot of shortcuts probably 6 on a regular basis. but have a few installed specific to my case.
the problem I have and seems its going to be resolved...when I need a script...I do not know if I have it installed already or not and I am wasting time
looking at my shortcut list trying to find it.
so I think if you have the search option you could basically install all the available Moi3d scripts (maybe download all as a package instead of one by one).
Me personally keep it as simple as possible.
In Nvil3d an example ... you highlight a plane/mesh section...go to the letter C I had setup on the screen and this will circulate the selection.....but this does not mean that the shortcut is assigned to the letter C on the keyboard.
there are other way to setup streamlines tools/shortcuts but the current setup works good enough and I did not want to complicate things.
so you have more space to setup your used commands.
to me this is a very nice setup and you can setup shortcuts from the tool search.
I always wished something similar in Moi.
Tnx!
12014.8
Hello, why is it like this?
12014.9 In reply to 12014.8
@ stefano - it looks like the .htm file is there accidentally twice, CommandPalette.htm and then same file again under CommandPalette.txt .
For forum attachments it should be ok to post files with .js file extension, it isn't sensitive to having .js files like e-mail attachments tend to be.
12014.10 In reply to 12014.9
好的,我习惯性的将txt后缀改为.js然后按常规方法安装脚本。现在我将其中一份删除了,请问该如何安装并使用呢?(Okay, I habitually change the .txt suffix to .js and then install the script using the conventional method. Now I have deleted one of them. How can I install and use it?)
12014.11 In reply to 12014.10
Hi SUIYAN, the same file was accidentally uploaded twice.
CommandPalette.txt which should have the .js content is instead another copy of CommandPalette.htm .
You won't be able to set it up until Stefano fixes it.
Show messages: All  1-6  7-11
