Command Palette ⚡ Keygroups (new)
All  1-15  16-17
12014.16 In reply to 12014.15
Cheers for the feedback Marc, hope it comes in useful at times...
12014.17 In reply to 12014.5
Now Live.!!.......
4 personality llama, on button
Following a key moment of inspiration, the Command Palette has been updated.
The big addition is Key Groups, where the multi function llama button returns to assist you
with inspirational shortcut duties.
Command Palette 1.45 with KeyGroups
Key Groups are user-defined tool sets for creating custom command panels.
They can contain commands, launch scripts, support workflow-specific tool sets,
and be triggered directly by MoI shortcut keys.
The new Group button creates, edits, and accesses Key Groups using a toggle mode.
Yo Llama Group button
Left-click: create/edit Key Groups (Function 1)
Right-click: switch between Command Palette and Key Groups (Function 2)
To create or edit a Key Group simply left-click the Group button, enter its name,
build or modify the tool set, then press <Enter>.
Using an existing name edits that Key Group; a new name creates one.
Names can be a letter, word, phrase, or abbreviation.
Example Keygroup names, might be:
>My Top Scripts
>Smirnov Top 5
>Drawing Tools
> "F" for file menu and save tools
>Dimension Kit
Preview:
Command line / shortcut syntax:
commandpalette
Opens the standard Command Palette.
commandpalette keys
Opens directly in Key Groups mode.
Not often used as tool remembers last toggle state now
commandpalette <yourkeygroupname> (no spaces)
Assign keygroup: My Top Scripts to a Moi3D Shortcut (options>shortcuts)
MoI3D MyTopScripts shortcut
Key zero opens that specific Key Group page called "My Top Scripts"
MoI3D MyTopScripts
OTHER:
A pinned keygroup is your favourite or default/most used keygroup.
Key Groups Presets are stored as JSON in:
`%AppData%\Moi\CommandPalette.KeyGroups.txt`
Please take care to name your keygroups carefully, there is no delete
currently. You can edit your keygroups text file if you want,
Advanced / Experimental
>KeyGroup Export
Shift-left-click Group to export the pinned Key Group as a small shareable text file. (Function 3)
These are saved like this:
CommandPalette.KeyGroup.mytopscripts.20260502-1749.txt
in location: `%AppData%\Moi\
>KeyGroup Import Ready (Function 4)
Shift-right-click Group checks for a future `CommandPaletteImport` / `CommandPaletteTools` command.
If not installed yet, it shows the Llamafield Keys Import future-release message.
Summary v1.45
• New Key Groups.
• Toggle between Command Palette and Key Groups.
• Create user-defined Key Groups.
• Build custom command panels for frequently used tools and workflows.
• Pin your favourite Key Group for quick access.
• Remembers the last active mode.
• Previous/Next navigation between Key Group Panels using mouse buttons or <> keyboard shortcuts.
• Direct launch of Key Groups from MoI shortcuts.
• Export pinned Key Groups as shareable JSON text files.
• NEW Base64 'Lightning' Icon for Max's Custom UI. left click for Command Palette, right click Keygroups.
Hope you enjoy...as much as i did building it for all you inspirational people...
EDITED: 6 Jun 16:48 by LIGHTWAVE
Show messages: All  1-15  16-17
