canopy fuselage and general workflow stuff
All  1-5  6-10
1201.6 In reply to 1201.5
>>>I think I see pilots in your B-17. Am I to understand that you just float them inside the plane and they are visible by virtue of the transparent material you applied to the window area, or did you "carve out" (Boolean or shell) your cockpit area?
The planes fuselage is completely hollow. It's just a surface so there's no need to boolean anything. I projected the window curves onto the surface and used them to trim the surface. Don't Remove the windows when trimming.
I did some googling and found a photo of the rocket you're modeling. Using the Project Curve to Surface should work for your window.
Steve S.
1201.7
Hi Steve,
Thanks, I guess I was trying to ensure everything was solid. It will be much easier if I can just put down surfaces for some things. The rocket is from "The Misadventures of Admiral Cornplaster: Part 1 -- Voyage of the Golden Spaceship El Dorado (Series II, Strips 181 to 216)."
Formerly I couldn't find any pics at all of it online, so I got the plastic modeling book I remembered it from when I was a kid, Famous Spaceships of Fact and Fantasy. I believe there was an Estes rocketry kit of it that I made when I was young, too, but haven't seen that online yet. I rechecked and I did find this version from eBay (attached).
If you have found a similar looking one could you remember what you searched for?
See you, --M
1201.8 In reply to 1201.7
This was the one that I found. It's similar, but not exactly the same.
http://billzeman.blogspot.com/2006/05/buck-rogers.html
For the one you posted, the side windows can be projected from the side, the front ones from the front, but for the one right on the corner you may need to rotate the ship and then project the circle. If you tried to project it from either the side or the front it would become distorted.
Steve S.
1201.9 In reply to 1201.8
1201.10
Hi, thanks Steve and Frenchy. I will try that out and maybe post back sometime when things are more together. I am doing engines now and the probably tricky wings next. See you later, --M
Show messages: All  1-5  6-10
