Bulls Horn
All  1  2-6
12009.2 In reply to 12009.1
Maybe you can try the OBJ format if your object is a pure quadrangles subdivision !
Maybe also decimate...before!
Direct conversion by the native SubD / Creat from File don't work for this case!
or by Import OBJ (by max Smirnov)
and you will have exact quadrangles to nurbs conversion following a %
With the original i am affraid that you can't make something with a such file! :)
here the importOBJ
3dm = 160 megs
zipp = 15 Meg https://moiscript.weebly.com/uploads/3/9/3/8/3938813/bull.zip
EDITED: 25 May 10:27 by PILOU
12009.3 In reply to 12009.2
Thanks a lot FP,
a first step. I try to moi-model a horn.
12009.4
It's a start.
I think I should create the sweep using multiple profiles, not just one. What do you think?
You could use this process :
Extract profiles selecting each segment of each profile.
Those profiles will be closed curves and polylines
apply A rebuild or reconstructcurve to have closed curves with only 1 segment. (A smooth version of your profiles)
Use a point for the last segment to have a pointed surface
Use all profiles and the last point to loft a clean surface.
12009.6
Hey, the model is triangulated because the STL format is for 3D printing, I think.
So I imported the model into Blender, went into edit mode, selected all the vertices, and used the Alt+J shortcut to turn the triangles into quads.
Now you can import the model using the SubD command in Moi3D and recreate the horns more easily. I’m attaching the obj model.
There are still some triangulated small zones, but is almost quad now
Greetings
Show messages: All  1  2-6
